cutie automata???
  • cutie automata???
    cum vi se pare acesta idee????
    Diversificarea ofertei e binevenita, dar in Romania nu o sa fie oferita. Si nici nu cred ca ar cumpara mai mult de 1% din clientela Dacia.
    Nenea ala de la Dacia vorbea despre Logan cand se referea la cutie automata, ca o posibilitate pentru viitor, iar asta chiar e invers de cum ar trebui ei sa gandeasca. Daca unui model de la Dacia i s-ar potrivi cutia automata, acela ar fi Sandero, datorita orientarii sale si spre clientele feminina.
    Oricum, din punt de vedere tehnic cutia aia automata nu poate fi prea evoluata.
    Ar fi ceva daca ar pune cutia automata de pe Clio II/III - (cod DP0) care este folosita si de grupul PSA. Lansata in 1997, are patru viteze, este foarte fiabila si in plus nici nu creste consumul cu mult fata de una manuala. Sort of fits the picture... componenta care si-a dovedt fiabilitatea si este deja amortizata - numai buna pentru Dacia.
    Si o descriere in engleza:
    In normal mode, the transmission is auto-adaptive, that is, it tries to shift according to your driving pattern. It considers the vehicle load, road gradient and surface, the speed of accelerator actuation and other factors such as gearbox oil temperature and engine temperature. The computer creates an identikit portrait of the driver within a minute, considering the speed of the car, the number of times and the speed at which the driver presses the accelerator (and its position). From this the computer categorieses the driver as being in an economical, sporting or medium category. These categories correspond with a set of gearshift rules which favour either economy, performance or a compromise between the two, which is determined from an average of values over the past few minutes. This can be temporarily changed if the accelerator is pressed rapidly - the ECU will select the next sportier program (ie. from ECO to MEDIUM or MEDIUM to SPORT) - upon release, the transmission resumes the earlier mode.
    Dar asta ar fi prea frumos. Eu cred ca vor folosi vechea AD4 care a fost si pe Renault 19. Tot 4 viteze.
      daca folosesc una mai noua,cresc preturile
        am vazut si un manual de utilizare in limaba romana pt cutie ,dar unii zic ca sunt doar pt viitor(alte modele dacia),si ar avea si scaune incalzite
          scaune incalzite??? nu prea cred
            Loganul pentru Rusia este echipat cu scaune incalzite. Banuiesc ca si Sandero o sa aiba aceeasi soarta, si PH2.
            Iar Loganul "de Maroc" are spalator pentru faruri.
              Eu nu pot sa inteleg de ce la noi nu sunt disponibile ca optionale.dar poate le vedem pe sandero cross
                vedem in viitor...
                  cutia automata nu va fi disponibila la noi, sau cel putin nu in urmatorii 2-3ani.
                    Stroe zicea ceva de anul viitor, cand se lanseaza si 1,0 16v.
                      mai dureaza pana o sa avem si noi asemenea masini cu anumite optionale sau serie care sa ne incante
