Am patit un pocinog. Am spalat masina si in timp ce o stergeam, a cazut in bara lampa de ceata dreapta spate.. Sunt in Austria si din pacate a cazut lampa jos din bara. Cei de la un magazin de specialiate au doar pentru Renault Laguna III. Nu stiu daca lampa se potriveste si pe deasupra cer 85EU pentru piesa.Vin cu rugamintea, daca stie careva codul acestui reper, ca nu ajung in tara decat la sfarsitul lui august.
Lampa ceata spate Stepway II
Ha ha ha, ascomp, ești foarte grijuliu cu banii noștri.
Și totuși, (del) Vecchio a scăpat ieftin. Ia te uită aici posesorii de Volvo din fanclubul american SwedeSpeed care se plâng că proiectoarele (nu banalele lămpi spate) le-au căzut, lipsindu-le șuruburile:
- "Help!!! Both fog lights fell out.
Ok, I have know idea whats going on. I saw that the drivers side fog light was hanging down from the car, I unhooked the wire harness, and it came right out. Its like someone unscrewed it and took the screws. So I decided to check the passengers foglight. When I took the grill off the fog light shifted, I moved it around and found that it to had no screws holding it in. I did find one screw laying inside the bumper. I had a hell of a time getting that one out all the way."
- Un altul tot acolo: "A few months ago, I found my drivers side fog dangling under the bumper. "
- Iar altul, tot Volvo: "Absolutely. The same thing happened to me. I came out of the mall and the drivers side was hanging down."
Pe forumul proprietarilor Nissan Infinity scrie unul după o baie a mașinii că și-a împins proiectorul în bară:
- "Loose fog light?
Ok, so I was washing my car because there's hella bugs on the front from driving out in Buttonwillow, CA. And as I get to my fog lights, the driver side fog light was loose. The bottom part of it like pushed in. "
Pe forumul Hyundai, cineva se plânge de același lucru iar altul spune că pare a fi o problema des întâlnită:
- "My passenger side foglight is loose. A bracket seems to have broken. Help please!"
Chiar la Vauxhall (Opel) se întâmplă, pe forumul proprietarilor de Opel Mokka (probabil că ei au luat moca mașina):
- "Hi, can anyone tell me how you get access to the rear offside fog light and how it is fixed to the bumper?
Despite there being no damage to the light itself or marks/damage to the bumper somehow the fog light has been pushed into the bumper on the right hand side of the light. It is still fixed to the bumper on the left hand side of light."
Pe forumul Citroen aceeași problemă, tot după o baie a mașinii.
- "Cleaning the car tonight in the rain, it always rains in Devon. Noticed the rear fog lamp was loose and flapping about in the rear bumper, if this a known issue"
Asta nu înseamnă că nu trebuie să îi tragem de urechi pe cei de la Dacia și Stepway-ul lor asamblat în Maroc. Vrem Stepway românesc, ca până în 2013, de bună calitate.
Mulțumesc pentru informații. Acu am ajuns acasă.
Presat de timp am rezolvat problema ca pe vremuri - fixare cu bandă adezivă. Au strâns probabil la montaj șurubul de fixare în bara mai tare și a crăpat suportul. Problema era că trebuia să traversez Elveția și cu ei am mai pățit-o!Nu mă cert niciodată cu oamenii proști; că mă pot trage în jos la nivelul lor și mă vor bate cu experiența!
